I've searched and came up with very little on block off plates. What all can I block off and not throw a CEL? What gains/differences would I be looking at? Is it worth the trouble? Thanks in advance.
Some block off plate questions
Members Ride Thread: LX ~ EX ~ For Sale Thread
Sold to: accord=inspire? ~ Accord214 ~ Raf99 ~ daheavyking ~ OHOYAMA ~ JunyAccord ~ CBsevenTUNER
Bought from: Joshy ~ TypeG ~ agol ~ 92smokeaccord ~ Extacee ~ mak ~ lindiz ~ illestatus ~ F20A CB7 ~ accord=inspire? ~ marcusv8thunderTags: None
Anyone?
Originally posted by 19dabeast85Blocking off the EGR will likely produce a smoother running engine, especially at lower rpm's and may increase your fuel mileage. However, it will also very likely cause you to fail emissions testing if your state requires that (Mine doesn't)
Blocking off the FITV will keep the engine from warming up as quickly in very cold weather. (If you live at Michigan latitude or more North, you may want to keep it)
Blocking off the Air Boost Valve will do nothing negative to my knowledge. It will very slightly increase throttle response from my experience. It's another one of those things there for extremely cold weather but even then I don't know that it really makes a big difference.
Blocking off the IAC will make the idle rpm completely dependent on where the set screw on the throttle plate is set at. It will increase throttle response but may cause erratic idle issues. If you use A/C, it will cause a really rough idle with the A/C on unless you have it set to idle around 1,100 with the throttle plate stop screw.
These are all mainly blocked off for the reason of eliminating possible vacuum leaks, idle issues, and engine clutter, and also increasing throttle response. Unless you are going full race or hardcore street/strip, I suggest keeping the IAC for everyday driveability. The Air Boost Valve, FITV, and EGR can all be deleted with little effect on driveability as long as you don't live in a really cold climate.
You'll want to check out Custom Billet Works website (page 7&8) to source some really high quality, professional plates.
Take note that the FITV plate above is for the h22/h23 and will not fit the f22 intake......search FS threads by member "frootloops" and see if he's selling any f22 fitv plates yet.My Member's Ride Thread
- 2 likes
Another thing about the EGR, if you are running an accord or prelude ecu, keep the valve connected to the engine harness and to vacuum. If you happen to have a chipped civic or integra ecu, the valve can be removed completely as well as the black emissions box minus the map sensor.
I highly recommend blocking the EGR especially if the service ports are clogged, night and day difference w/ light throttle acceleration @ 1800 ish where the EGR is active.
^Yes, stud pattern is all the same. Not a huge deal, but there's 2 different casting shapes, the superman logo/diamond shape found on the F22A for example and the 4 leaf clover shape found on the H23 and H22 for example. I'm sure you'll see 2 diff. types on eBay but they are all interchangeable.
my jdm h22 IM had an air boost valve block off plate that looked oem..fit right on my a6 IM without any modifications..no CEL either
Rush
Originally posted by DarkcloudBought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
Originally posted by bmxicansdso you got a boombox, sunglasses and rosettta stone?
After comparing a h23 and f22 fitv I'm pretty sure the h23 plate will not work on the f22.Originally posted by Granite CB7 View Post^Yes, stud pattern is all the same. Not a huge deal, but there's 2 different casting shapes, the superman logo/diamond shape found on the F22A for example and the 4 leaf clover shape found on the H23 and H22 for example. I'm sure you'll see 2 diff. types on eBay but they are all interchangeable.
Yeah but I've had no luck searching for that part, pretty certain they aren't made anymore, at least as individual parts.Originally posted by cb7rush View Postmy jdm h22 IM had an air boost valve block off plate that looked oem..fit right on my a6 IM without any modifications..no CEL eitherMy Member's Ride Thread
Sorry, I don't know why I read "fitv" instead of "egr". Yeah egr plate is the same for most honda engines.Originally posted by Granite CB7 View Post^
We were talking EGR, but you're right, F22 FITV is much diff. from H series.My Member's Ride Thread
