XTD Scam...
This topic is closed.
    XTD Scam...
    I can't say with 100% certainty that this is true or not, but something to consider if it hasn't already been discussed. This is pulled from SupraMania.com
    Originally posted by bigaaron View Post
    We are having clutches made for us by Action Clutch. They make us an upgraded pressure plate that is 40% heavier spring pressure then stock. Recently, someone brought to my attention the they could buy the "same thing" on Ebay for over $200 less. I was REALLY supprised to hear that, because we don't have a lot of margin on ours, and I was wondering if we were just paying way too much, or if it was too good to be true. Since XTD is only about a 45 minute drive from the shop, I went there in person to check it out. He seems to do a lot of business on Ebay, there were about 20 orders boxed up to go out, and since many of them were not taped up, I noticed that he had more then a few 7m-gte clutches to be shipped. At the bottom of a huge stack of Aisin (oem toyota) boxes, I saw a few Action clutch boxes. That was strange, because Action said the do not sell anything to this guy, and they were wondering why he had their boxes in his business. I found out why!
    I bought one of his pressure plates to take to Action to test, and to take pics compared to stock. THE XTD PRESSURE PLATE IS A BONE STOCK PRESSURE PLATE, SPRAY PAINTED RED. We had Action put it on their pressure test machine that tests the clamp pressure, and also a stock Aisin Toyota pressure plate. The XTD clutch was actually 100ft/lbs LESS then the other stock unit we tested. His Ebay auction clearly states the XTD pressure plate is "35% thicker heavy duty" spring in it. I measured the XTD and stock springs, they are exactly the same thickness. He is clearly lying, and fooling people into thinking the XTD clutch will handle 35% more, when in fact it is stock. If you remove the XTD sticker, you will see the stock green paint mark underneath :biglaugh: If they were heat treated to increase the spring pressure, that paint would most likely have burned off, and the spring would be discolored.
    Also, I looked closely at the XTD 6 puck disk. It looks like a cheap copy of the Action one. If you look at the pics in his Ebay auction at the top it is an ACTION CLUTCH KIT IN THE PICS. The one he actually ships is in the pics at the bottom. Action clutch does use a stock Aisin outer clutch cover, but the rivets are drilled out, and then the spring is upgraded and the clutch is reassembled. Other companies also do this, because Aisin is the only manufacturer of this model clutch.
    Here is a link to his auction on Ebay. If you want to be overcharged for a stock pp with cheap copy 6 puck, that's up to you.
    http://cgi.ebay.com/ebaymotors/XTD-S...06058632QQrdZ1
    Notice the first pic on his Ebay auction is an Action Clutch pp with an XTD sticker on it. You can tell because the spring is dark black, and the pp was disassembled before painting. You can see around the inside edge at the top.
    Here's what he is actually shipping:
    Compared to a stock pp:
    The real Action upgraded clutch has a black spring and is painted while it is disassembled. It has a 40% higher pressure spring then stock.
    The real Action 6 puck has a slightly lighter color on the pucks, and has little slots in the center of each puck.
    I really don't have a problem with Ebay, or Chinese made parts, what I do have a BIG problem with is people on Ebay misrepresenting the specs and performance of their parts.
    My official vouch thread!
    Updated!!! --> My official turbo progress thread
    *chuckles to self
    ...thanks for the heads up! Damn...WORSE then stock!!!
    Does xtd put their logo on the spring like that fake does?
    ____
      i was always told that the guy who owns xtd used to be with the guy that does act. and he broke away on his own and was making the clutches just like act and selling them cheaper. this is just what i heard. i have driven a stage 3 xtd and it is way way more grippier than a oem clutch. on my swap now i have a stage 1 clutch and there 12lbs fly wheel. like i said, this is just what i have heard through the grape vine so what is actually true i am not sure.
      Hola, tengo tres patas. Me llamo tripod.
      Originally posted by d112crzy
      So you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
        DO you know the seller name?
        Do all XTD products come from the same place?
        That sucks. It would explain why mine is pretty much fucked after only a year.
          According to the RCMP, more than 50% of car parts in the North American market are either fakes or well under-engineered. sux
          That's why I try to source parts from the authorized dealers or directly from the factory.
          good post.
          DEVOTE
          FS: Lokuputha's Stuff
            My XTD stage 1 clutch was slipping after 6 months, and gone in just over a year
            Originally posted by DoctorCipher
            ...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
              I think the hq is in California somewhere. I have a stage 3 with no hitches so far. Grips pretty well.
                perhaps mixed cases of real and fake clutches....
                  i dont get how its oem parts yet last less thab oem quality. ya kno wh mee?
                    I am pretty sure the only distributor of XTD clutches is Aimcoclutch on ebay.
                    Gary A.K.A. Carter
                    [sig killed by photobucket]
                      I kinda wish I could go drive my car right now to see just how grippy my xtd is..
                      To-Do List for Today
                      Be Awesome
                        eh i had my xtd stage one kit for over a year with no problems at all after breaking it in properly and all. still grips fine.
                        The CB9 has been reborn into a CB3
                        Members Ride - see my cb3 here - DOHC powah
                        Check out my JDM F22B swap
                        Watch my CB7 video
                          Never know with ebay. They have fake rebadged teins and other stuff. Never know. Personally if I was going with a clutch for a supra I wouldnt go with xtd lol. Even though they recently came out with a stage 4 from what I have seen lol dunno how that is gonna work. I am looking at an RPS setup the only thing I am worried about is that its going to be too harsh on the trans since those are sturdy pp's. Action wouldnt be a bad option too didnt know they make clutchces for supras.
                            I'll probbly end up with either centerforce, clutchmaster, or exedy... I don't remember all the brands, but those are some I do know of.
                              Yea those are nice too. I just want to buy something that will hold up to my power goals so later on I dont have to spend more on another clutch I later need. Just put up the money now and wait later =D But clutchmasters/centerforce should have a good combo for the setup you listed you wanted to run.
