Well, the new motor is in and the tuning happens this week...hope everything goes well. Here's the build. It will be tuned using Neptune and I do have an hks ebc. I will be bringing my camera to take a few vids. Hoping to make close to 400whp at 15psi...wish me luck!
HEAD
-1993 JDM H22a DOHC VTEC
-skunk2 pro series stage 1 cams
-skunk2 pro series cam gears
-skunk2 pro series valves
-skunk2 pro series titanium retainers
-skunk2 pro series valve springs
-skunk2 pro series intake manifold
-skunk2 pro series 68mm throttle body
-brand new jdm distributor
-custom painted valve cover w/ cut outs for cam gears
-3 angle valve job
-Cometic head gasket
-ARP main studs
-hondata intake manifold gasket
BLOCK
-jdm h22a block
-Mahle Gold Series 10:1 Compression/Stock Bore
-Eagle Forged H-Beam Rods
-ACL Main Bearings
-ACL Rod Bearings
-ARP Rod Bolts
-Balanced and Micro Polished Crank
-Kaizen Speed Balance Shaft Eliminator Kit
-New OEM Water Pump
-New OEM Timing Belt
-H23 Manual Tensioner Conversion
-ARP Head Studs
-Moroso Oil Pan
-Moroso Oil Pick-Up
HEAD
-3 angle valve job
-ARP main studs
BLOCK
-jdm h22a block
-ACL Main Bearings
-ACL Rod Bearings
-ARP Rod Bolts
-New OEM Water Pump
-ARP Head Studs
-Moroso Oil Pan
-Moroso Oil Pick-Up
