No, not at all.
Im not going to turn this guys thread into an arguement about engine building.
Briefly I will say this;
Length of stroke plays a key role in dwell times and piston speed. IF, and this is the big question here, IF, you are going to play with a rod/stroke ratio while building a turbo motor, you should take that into consideration.
Lower piston speeds as well as a shorter stroke allow a higher rev. This is fact.
The overall speed the engine can spin to has a huge role in how much air the engine moves, in cfm. The cfm the engine produces has a huge role in what size turbo it will power best.
If you are going through all the hassle of swapping cranks, rods and pistons for a turbo motor-it would be counterproductive to do things like swap in a longer stroke crank, or higher compression pistons.
Can you run a turbo on high compression pistons? Sure.
But it would be counterproductive to do so if you are specifically building the engine for a turbo application.
