which transmission for f22 turbo?
    i have a 300hp turbo F22 and my transmission need a rebuilt.
    what would be the best thing to do ?
    my first choice is to have it rebuilt by a friend. he can do that for under 200$
    but i'm thinking about putting a LSD diff in it. is it the money? is OBX lsd good?
    i know quaife is best but i'm not willing to spend 1000$ on a diff..
    or should i buy a used m2b4 lsd prelude trans?
    i'm not very hard with the car and i don't race with it.. i just want a sport feeling when i drive the car.
    My Ride
    Jas Airbrush, Custom Paint.
    The LSD prelude Trans has short gears because it was made for the H22, I would say your fine with a rebuild as long as you get quality work. 9/10 you get what you pay for. If getting a better Trans is all your after I say your best bet is an H23 Trans. Just my 2cents
    I wake up in the morning and piss excellence!
      H22 or h23 transmission if you want to be faster. I found my last h23 tranny for pretty cheap, and my obx LSD has seen over 600whp and holding up fine. My diff is also from like 2005 so I can't say if the quality has changed since then.
        Since your have a turbo the best transmission choice would probably be a transmission from an f22a, as the longer gears will help keep you in boost longer.
          An auto JDM MP1A w/ LSD would be a great match. Short gear ratios but you don't have to let off the gas to shift so you don't fall out of boost.
          A manual to auto conversion is a very involved conversion though...
            I sent my transmission to have it rebuilt
            I can have rebuilt kit from synchotech. they are 2 kits available (single cone 2nd or dual cone 2nd) but the sticker on my transmission is gone so i have no idea how to identify my transmission. the only thing i know about this transmission it's that it come from a cb7.
            the rebuilt kits available for accord are the 3rd and 4th from the bottom of the page.
            http://shop.synchrotech-transmission...Series_c19.htm
            is all cb7 using the same type of transmission (single cone 2nd or dual cone 2nd)?
            is it another way to identify the transmission to order the right rebuilt kit?
            My Ride
