go to a performance shop such as ben pilla or a nitrous retailer. im sure you can find a performance shop in yellow pages around where you live. look for shops that deal with domestics alot cuz those guys usually run lots of nitrous
Also one important thing you guys have to remember when talking about dyno numbers and front mount intercooler is the FMIC only works when it has air hitting it at decent speed, it works even better if it has cold air hitting it (running through the fins) at high speed. You do NOT have this at a dyno, the fan they put in front of your car can not substitute for opposing wind outside doing 50-1xx mph so when the intercooler is sprayed with cold gas it obivously drops the intake temperatures alot. In reality when you are at the track or on the highway you do have more power running the fmic then the dyno showed, the intercooler wont be as cold as it can be with nitrous sprayed on it so there is still a gain on the street from this setup but it wont be 30-40 hp!
), when i found a vid of a green supra that gained only 72whp with a T88 turbo?
