Originally posted by gloryaccordy
4g63T vs. f22a, 16g vs. 14b
1st gen 4G63 have 7.8:1 compression
2nd gen's have 8.5:1 compression
F22's have 8.8:1 compression
just a couple of facts cause i don't feel like putting in any real input lol.
Also you can't take the stock Flywheel numbers for the dsm's and compare it to WHP of f22's with dsm turbo'sKnowledge is power...in EVERY sense of the word
Originally posted by AcclipseH23And thats true on the last quote that appeared out of nowhere...
>>>>Originally posted by flacopowerit takes 14psi stock on a pos t25 to push 205hp and 210ft/lbs on a 2nd gen... and we have 9:0:1 compression i believe..Knowledge is power...in EVERY sense of the word
didnt read the whole thread but since i have/had both here goes....
the block in a 4g63 is iron.... 2g dsm have t25 (weak turbos, specially at high boost)
stock 1g has 14b and sometimes 16g.
a 14b can put a 1g at 18-20psi into the 13's (low 13's dont believe me check out dsmtuner.com). i seen a go stock 14b dsm 1g at 20-22 psi killing corvette's. now u also have to take into factor if the cars AWD.... some are FWD, some are AWD (thats if u want to compare times at the track)
as for the motors.......
u cant compare a weak turbo to a fairly nicely powered turbo..... who here would put a t25 on there cb7 vs. a 14b or 16g? no a lot.....cause there weak. dont know why they thru them on the 2g dsm's but manufactures do things like that
and yeah the blocks are good for 400-mid 400 easily, with proper Tur. and supporting mods.
but i cant really give u all a what i like better veiw yet..........
i brought my dsm with a shot motor (couldnt beat 600bux for a 92 tsi with 80k miles on the body...lol.... damn i miss my project cb7....lol)
but i will give u all some insight once i get her working.
also the motor size is 2.0, not 1.8...... 1.8 is N/A 4g63NEED RAP BEATS.....
www.soundclick.com/akcidentaltrakz
also the motor size is 2.0, not 1.8...... 1.8 is N/A 4g63[/QUOTE]
The 1.8 is the 4g92 I've owned two of those beast in my life. 90 HP baby! Booya.
the 2.0 is just the regular 4g63 No T at the end. This helps for deciphering the engine codes of mitsubishi.
The number and lettering system of Mitsubishi engines can be a little confusing, so here is how to decipher them:
Numerical Prefix -
4 = four cylinder
6 = six cylinder
Numerical Suffix -
12 = 2.0 litre
13 = 2.5 litre
36 = 2.0 litre
54 = 2.6 litre
61 = 1.6 litre
62 = 1.85 litre
63 = 2.0 litre
64 = 2.4 litre
72 = 3.0 litre
73 = 2.5 litre
74 = 3.5 litre
91 = 1.5 litre
92 = 1.6 litre
93 = 1.8 litre
I guess the final thing that we have to add into this whole little thing is that the 1g DSM's and 2g DSM's run close to 1k more weight than the sedan cb7's, and you all know what weight does to your times. In the end I think we're comparing apples and oranges here.Last edited by 91accordwagon; 11-08-2005, 05:06 PM.
http://www.nippon-motors.com/mitsubishi.htm
check out the link.....
plus i have one sitting outside in my 1g right now.... i see it every day.
4g63t 2.0
theres other models some not ending with 63, like there was a mirage turbo motor, its a 1.8 i think its 4g62 or something, but i seen it being sold at a junk yard. wouldnt working in my car because it doenst have enuff torque to pull my heavy ass car....lolNEED RAP BEATS.....
thats part of it.....theres so many dsm motors........(for those that dont know talon and eclipse basically have the same motors depending on the model)
1g's 88-9o somthing are 4g63 and 4g63t.... some 2.0 some 1.8
420a are in the newer (not new new) eclispe, like the one in 2fast 2 furious....
theres the 6bolt, the 7bolt and the 420a'sNEED RAP BEATS.....
o yeah one more thing.....
For extra info............
its not wise to take a 4g63 N/A motor and make it turbo..... u can do this but thinking u can do the same thing as if it was a 4g63t isnt smart. the internals used it the N/A 4g63 motor arent as strong as the t-version, and cant handle as much boost. a lot of people try this and blow there motors trying to turn up the boost like in normal t-versions. this is one reason why im being patient and saving up the cake for a 4g63t and not just getting the 4g63 for 300-500bux and slapping my turbo parts on it.
just a lil more info for ya........
also here u go.....
There were four models of the Talon/Laser:
base DL/standard Hatchback
ES/RS
TSi/RS Turbo
TSi AWD/RS Turbo AWD
The base model was front wheel drive and home to a low-power 1.8 L engine. The RS model sported a naturally aspirated 2.0 L Mitsubishi 4G63 engine. The TSi/RS Turbo and AWD (all wheel drive) models were powered by the same engine, with the addition of a turbocharger to boost performance significantly. Note that the RS Turbo AWD Laser was not available until the 1992 model year.
the DL model (for the talon) had a 1.8 in it.
those ubove are the talon models.......
eclispe are: gs
gs-t (FWD)
gsx AWD)
sont know if there are any more models (dont know the models of the newer ones) but depending of the years they either came with the t25 or 14b (some 13b) and if u got lucky a 16gLast edited by theone; 11-08-2005, 07:25 PM.NEED RAP BEATS.....
