first thing first
the setup:
H22A4(comp 200/195psi on cyl.)with the stack delete on the IM,
EURO R TB,
F22 injector(for now)
CHIPPED P28
H23A trans
o2,fitv,knock sensor,crankshaft,egr,canister all delete
problem:
so as seeing on my mrt i been busy working on my motor. now its just been tweaking and testing. anyways back to the point today i clean the ivac out due to bad idle so i fix the idle by cleaning out the ivac and adjusting the TB since the euro r tb dont have a idle screw. so went for a test drive while out on my test drive i wanted to see how the motor would run on top end so i punch it from 3rd gear at 75mph when I got to 5th gear I'm noticing that my car is not passing 110mph and it took awhile to get from 100 to 110mph. now i cant figure out why. shoot i tapped out my cluster(130++) with my f22 with bolt-ons so i'm like wtf is going on here
so if anyone has had this problem before or know what could be wrong and can help pin point the problem that sure would help me alot
Thank in advance
the setup:
EURO R TB,
CHIPPED P28
H23A trans
problem:
Thank in advance
