I am eventually going to do an H23 swap and it has been recommended to get a new clutch assembly. I would like to get a light weight flywheel with a brand new OEM clutch, probably Prelude assembly. The build plans for the H23 are basic I/H/E for awhile. Will the clutch setup work reliably enough for at least 5 years of somewhat aggressive launches? If you need to know why I want OEM, cost and stick to OEM if possible.
Oem Clutch + Light Flywheel
Be unique, like every other person.
CB7 Sold________________________E34 Sold________________________E39 Current
Tags: None
Any launching is aggressive. There isn't a launch that's easy on the clutch. If you're going to be doing any drag racing at the track I'd look into an upgraded Exedy. If you're launching on the street, stop driving like a jackass. If you don't really mean launching and more of a spirited driving style then you'll be okay with the Exedy clutch kit for the H22A Prelude.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Well Autocross mainly is where the aggression is and I guess spirited is a good way to describe my street driving. The question I have is will the Exedy be good for daily driving in traffic after some learning or will it always be jumpy when starting to move?Be unique, like every other person.
I have an ACT StreetLite flywheel with an OEM replacement Exedy clutch on my H22. No problems at all. Drives nice and grabs just fine.Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
IM with the rest of the group. I used an act lightweight flywheel and exedy stage 1 clutch and it felt great. The flywheel is where it counts cause you will have quicker throttle response. Grabbed great and was easily streetable. But by no means would I drag or launch it at every stop light lol just be reasonable.
yea right now i have a fidanza 8lb flywheel with brand new friction plate with an oem exedy clutch on my h22 cb and so far so good im still getting use to it. since i use to have a xtd s1 and before that a ACT heavy duty pressure plate 6 puck clutch lol same flywheel so far so good im still in the breaking period so haven't lunched it well i have once or twice lol
HomeAutomatics
OEM ClutchRace Clutch
CatalogsTech Info
Tech VideosNews
Dealer LocatorContact EXEDY Sports Clutch | Street - Drag - Rally - Circuit EXEDY Stage 1 performance clutch kit
Ultra-Fiber Organic Disc
EXEDY Exclusive Friction Composition
High Heat resins bond friction fibers
Unlike competitors, EXEDY friction material
has no need for steel backing to pass SFI burst test
Maintains drivability of an OE-style disc
Heavy Duty oil-quench hardened damper
Heavy Duty rivets retain clutch material
High Performance Cover
Average of 40% increase in clamp load
Extra capacity holds common street car upgrades
Ductile iron pressure plate provides high strength,
anti-burst protection in all temperature ranges
Stamped steel cover designed to reduce deflection
Stage 1 EXEDY clutches and chromoly flywheels are SFI Foundation approved APPROVED
Street Performance
EXEDY Ultra Fiber Clutch Disc
"EXEDY" and the Exedy Logo are Registered Trademarks (United States Patent & TradeMark Office No. 76482354)
© Copyright 2013 EXEDY Globalparts Corporation (EGP) ALL Rights Reserved.
Spec 1.1 Replacement Flywheels and Clutch Assemblies
Spec 1.2 Multiple Disc Clutch Assemblies
Spec 1.5 Multiple Disc Clutch Assemblies for Supercharged, Nitrous-Oxide Injected, and Turbocharged Vehicles
EXEDY organic racing clutches only use premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. This is the preferred clutch for street and light horsepower track use. Drivability is similar to the stock clutch. Pedal efforts will be slightly higher because of the higher clamp loads. All of our Stage 1 clutch discs have spring center dampers to reduce drivetrain shock.
Exedy stage 1 will be just right and hold up better due to the higher temps that come with any type of competitive driving.WWW.JDMCONCEPTS.COM
Keep .It. Simple. Stupid =K.I.S.S
