1. What length bolts do I get for double stacking?
2. What size are the vacuum tubes(if I want to get aftermarket)? Are they all the same size?
3. When doing the IM manifold swap, can I remove the fuel rail, injectors, and black plastic piece as one assembly, and change only injector to manifold seals?
4. When wiring the IAB's, I read that the pink wire goes to pinA17, and the black one, I either ground it to the chassis, or connect it to a existing ground wire?
thanks in advance
thanks in advance
