Sorry, I haven't ordered mine yet. I would think it's the same, though, or people would report leaking, if you have an old filter laying around to measure. There's also that threaded male piece that the filter screws onto that you'll need to figure out as well. Do a search for Honda oil filter sandwich plates and they should detail the specs.
*ED. - I feel your pain, and I'm remembering now why I decided to try other tricks for the oil system over getting an Accusump. I'm getting into this search process all over again trying to help you out, and looking at all these different fitting sizes and adapters is making me feel dumb.
This thread on an S2000 install was an interesting read:
https://www.s2ki.com/forums/s2000-ra...nsors-1038799/
Found these parts... again, I'm feeling dumb after this, so a second opinion is strongly recommended:
Going off that guy's experience I looked into Mocal. Here's their sandwich adapter w/20mm thread for oil filter compatibility, featuring two 1/2" BSP ports:
http://www.improvedracing.com/oil-co...ate-p-687.html
They also offer a thermostatic version of the same sandwich adapter:
http://www.improvedracing.com/oil-co...ate-p-688.html
And then here's a 1/2" BSPP (the second P referring to parallel threads, as opposed to Tapered; I assume that's what the Mocal port is) male to 1/2" NPT female adapter for the Accusump plumbing:
https://www.amazon.com/BRASS-ADAPTER.../dp/B015ROB2NW
Then of course you could get a 1/2" BSP plug if you don't need that other port, or an adaptor for a sensor or something.
