build up of JDM F20B DOHC VTEC
    Originally posted by gloryaccordy
    If ur changing the rings... why not go with aftermarket pistons? The F20B doesn't have the lame azz FRM sleeves does it?
    nope it doesn't which im happy about
    PSN ID's:Tidashoni
    1992 Accord EX Coupe
    My FS Thread
    Not so DD 2013 Subaru Impreza WRX STI
    Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
      my plan was not to spend much money on this motor. I mean, I only spent 38 dollars and some change for this motor.
        long time since i checked this thread, but what the heck, ill fire it back up!!
        been busy with school, but im still in the market for a good header, which after i purchase and put on, car will get a dyno tune!!
        runs super rich now, so rich it floods itself to the point that it wont start for a while (till plugs dry off im assuming?)
        anyways...
        Past 1990 Accord EX Sedan
        Past 1990 Accord LX Sedan
        Past 1991 Accord LX Sedan
        Past 1993 Accord LX Wagon
        Current 1991 Accord EX Wagon
          anyways...
          You should be aware that this "too rich" condition will interfere with your motor oil lubrication and break-down it down. You should be changing your motor oil more frequently than normal intervals to prevent damage.
          Can't you atleast tweak the tuning some more or have it done by someone so that it is not this ridiculous. I would hate to see such a fine motor go to waste.
            what map are you running now? the one juan and i have been? if you are still running the obd2 270cc injectors i really hope juan scaled the map...because it was set for 345cc obd1s...
            Retired 1990 Accord LX Coupe
            Project 240SX
              guess its time for an oil change
              no idea, ill have to ask him
                if you wan you can use mine its set for 290cc injectors ill richin it up a bit for you tho cause if you wer to run it there youd be running lean with it
                PSN ID's:Tidashoni
                My FS Thread
                  well since my motor is the base model f20b and had the sauce parts on it, cam shafts were teh next thing in line to upgrade. so i bought a pair of type s cams from a member on here, so i should have those in hopefully over the break hoping for some decent results
                    Hey Eli you know who could probably help you finding aftermarket parts. I don't know if anyone has heard of the place but its called Pac West here in Salem. The guy is amazing with hondas and his shop is near by me. You should talk to him about parts. He also has the fastest civic on the west coast from what i hear.
                    My Member's Ride Page (Do it)
                      we should totally set up a time and roll down there and check it out
                        Im sure your busy this weekend with studying for finals...but if you got the time i do at least...let me know.
                          Off topic...
                          Beavers WON!
                            Originally posted by CisForCB7
                            Off topic...
                            Beavers WON!
                            wewt! we should go to that shop in salem like on tuesday
                              hmm tuesday... thats my last final day... Wednesday? would that work? If not tuesday i can work out but has to be before 6:30 i got my final then.
                                little up date..
                                i have h22 type s cams waiting to be installed
                                i ordered a ESP header, should be here in a few weeks
                                after i get both those installed i will be heading to portland for a tune
                                the car still is having problems. running rich.. if i start the car or drive it, then shut it off, it has to sit for over an hour before it will start again...not sure why. also the battery wont hold a charge. i think that is because it is in the trunk, and the wire gauge is kinda thin, so the current is weak?
                                so the car is sitting with a dead battery, im bored so i think ima go strip more parts off in the interior
