Alignment issues after traction bar install
    I recently got an alignment done on the cb after installing an ESP traction bar because I was feeling some weird steering issues. Plus its good anyway.. The tech says that my caster is way off and the traction bar maxed out of adjustment. Like physically maxed out no more threads. He said it needs to be like an inch more forward to get the desired caster. Have any of you guys heard of anything like this or have a solution? Also, I have FFC rear LCA's and Toe arms. And now he is saying that I need adjustable rear toe arms to fix the toe?(After spending all that $) What are the best adjustable rear toe arms for the cb? Megan is the only ones I've found and I usually do not like Megan products. Or of some way I can fix toe with the FFC rear toe arms would be ideal! Thanks guys any input would be appreciated
    I haven’t had an issue with getting the front aligned. Especially caster, toe was always the issue with my set-up but that’s because of how low I am. It would rub the fender to get it into spec. What’s your suspension set up?
    As for the rear I have FFC rear LCA and Toe arms. I haven’t gotten the rear aligned yet, but I believe your only option is Megan and I think hard racing may make some. Or doing the washer trick.
    ~Nick~
      I've had no issues too. Running 3.4 - 3.8 caster on the front. With a ESP Traction bar. And mine is maxed out too. Whats your #s?
      You'll need some rear camber if you're going low. I use ingals as they have the angle to them.
        Setup is GC/Koni yellows.. I usually stay away from Megan but it seems those rear toe arms do get decent reviews so that may be an option for the rear. My main concern is the front tho
          Nah, I'm not too worried about rear camber, unless you're talking about one that can effect toe as well? But yeah, caster is 2.5 Lf and 2.3 Rf MAXED out. Camber's 3* and toe in front is .01* Rear toe is off .3 and .12*
            Riight, so something is not correct. Your ESP bar is showing no threads like mine?
              Yes sir looks just like that.. idk I’m gonna have to do something.. either switch to an Innovative traction bar or go back to stock crossmember.. because let me tell you I can feel it, steering feels sketchy af
                But hold on. Are cars are identical and the amount of lowered doesn't account for the caster. (I'm 2.2" lowered running 2 degrees camber). So this implies your ESP bar is different. Measure the silver part of the ESP traction bar, what's the length?
                This and does your wheel not look centred in the wheel well?
                edit: the LCA portion installed correctly too?
                  Bump for update? I just finished installing mine, so the thread's making me a bit nervous...
                    Nah, no update yet.. the car's in the body shop right now, but I plan on tackling the issue once it's out..
                      I wonder what caster degree the alignment guy was trying to aim for? What's OEM? mine is 3.4 - 3.8 caster...
