So I read the DIY about how to swap the gears from the CB VSS to the U2Q7 trans. But, I also read on a few other threads on "VSS" about how people have just swapped the whole assembly over to the H22s without changing the gears & have had success.
When I pulled the VSS off my T2W4 the gear was a lot longer than the CB's gear. So I did not want to take the chance of shredding up the gear if it did not match up. I also pulled a VSS off of a A/T CB & the shaft that holds the gear has a different ending tip, that narrows towards the end.
Do I have to switch the gears on the VSS or can I reuse the whole CB assembly?
http://www.cb7tuner.com/vbb/showthread.php?t=148437
