Originally posted by porter351
View Post
A/c delete
Originally posted by quickangel93 View Postmy car did. i had the knob on cold and fan on full blast. and it was hot air
knob to have heat then the temp goes up significantly. essentially when it
is at the coldest you are getting outside temp from the engine bay (i believe, i
could be wrong though). telling people that the heat is always on is kinda
misinforming
I wish there was a facepalm smilely lol
No...the heater valve on almost 99% of our CB's today is worn out and the cable that runs from the knob to the valve is un-adjusted.
The cable is held by a screw with some teeth that clamp the cable to the climate control.
Years go by, this cable slides slowly...nothing hard to grasp.
Easy to fix though, just crank it to cold, pop the hood, fully close the heater valve.
My A/C gets ALOT colder once I close the heater valve all the way.
I've had 3 other accords do this aslwell, and fixed a few other A/C related problems with this.
Also the outside air is picked up where the windshield wiper cover is, so I guess it can pick up hot engine air
like they said, as long as your heater valve works it should just blow ambient temperature air at the coldest. as for other components, there is an extention to your driver's side wiring loom that can come out when you pull a/c. it is the harness connected to the two rubber-covered relays, just un-bolt those then pull out everything up to the connector. with that, you can pull out the driver's side radiator fan as well since it is connected with that harness.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
thanks for all the replies, suggestions, and advice. will definately come into use when i go to pull everything out.We are all ricers, it just depends what flavor rice you are.
Minitrucker by heart, CB7tuner by coincidence.
My For Sale Thread
Bowling Pin Shift Knobs
