I've replaced my passenger side break light housing and fixed the leaking as well as replaced some of the parts a couple times, but whenever it rains the break light (on the dash) comes on and I double check everything and nothing is leaking anymore. Is this a common problem?
Also when it's cold or rainy outside my ABS light on the dash doesn't come on anymore but when it starts to get nice and warm out the light comes back on, so I was wondering if anyone else has any ideas, thanks.
Fluids are fine and I've had the break light problem for a year and no luck getting it to go away. ABS recently started popping on, on the cold/rainy days it drives fine and works. I would check the codes for the ABS but I think it may have something to do with the wiring. It's also not the e-brake I'm pretty sure because I adjusted it well. I've read through the forums and there's similar problems but mine seems different.
- maybe a loose sensor, or a damaged tone ring?
