Power Mirror Switch
    Power Mirror Switch
    Ok, so i had a issue with my power mirror switch.
    As i went to adjust my mirrors, my mirror starts to move on its own towards the right. As i press it to go left, it stops. Going up and down is fine, but i cant control right or left.
    I went to the Junkyard and found me 1 switch for removal (hard to find door panels intact or still on the door here in Cen-Cal)
    I put in the switch, and it has a worst issue than what i had, it goes up and right, and i cannot control down or left.
    So i opened up the switch and re-soldered the board and it seemed to work fins after that. But that was 2 days ago and now it is acting up again. What can be the issue?
    I made sure the new solder was put on correctly so it made a good contact and so it wont crack during installation.
    Any suggestions?
    MRT
    Wow, you pretty much did everything i would have already
    I gusse the next step is to check the wiring
    Maybe you got another bad switch too?
      Or it is in the mirror itself. Do both mirrors behave the same way?
        I did get another bad switch, but i re-soldered the one i pulled from the junk yard and it worked fine for the first 2 days, then went haywire again afterwards.
        Yes both mirrors behave the same way. When i switch it to the middle where it doesn't control either mirrors, it stops, but as soon as i switch it to any mirror, it goes haywire.
        MRT
          I had the same issue.
          Buy a new switch.
          Originally posted by Jarrett
