Okay I've done a good bit of work on my cb this year replaced
Radiator
Bled coolant
Thermostat
2 of the 3 sensors
Lower rad hose
U shaped hose in the back of the engine behind the thermo housing
I run pre mixed coolant
But for some reason I will fill up my resivor and its dry after a bit of driving and
I guess it took in more than it could and blew a hose on my oil cooler
I don't want anymore pressure blow out's what can I do to prevent this and looking under the cap in the rad with car at temp what's a full system
1 just over the fins in the rad
2 at the neck of the rad
Thanks
Radiator
Bled coolant
Thermostat
2 of the 3 sensors
Lower rad hose
Thanks
