code 9
    code 9
    i got a fuck you special dizzy from autozone and now my car has a cel for code 9. i read up on it and they say you have to replace the dizzy to fix it. this is gonna be the last dizzy they'll give me from autozone. ive been through 6 due to poor quality.
    COUPE K24
    venting? or are you asking where to get a good one?
      Is there anyway to fix it besides replacing it again?
      COUPE K24
        If replacing the dizzy doesn't clear the code (you are resetting the ECU after each swap right?). Then you have a wiring problem. Either bad wiring, bad ground building capacitance and destroying the CYP sensor, or bad connection.
          Is your car running normally?
          IT IS WHAT IT IS
