i got a fuck you special dizzy from autozone and now my car has a cel for code 9. i read up on it and they say you have to replace the dizzy to fix it. this is gonna be the last dizzy they'll give me from autozone. ive been through 6 due to poor quality.
code 9
If replacing the dizzy doesn't clear the code (you are resetting the ECU after each swap right?). Then you have a wiring problem. Either bad wiring, bad ground building capacitance and destroying the CYP sensor, or bad connection.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
