This is a basic how to.
What you need are a large GM fan clutch wrench and a 2" nut.
Weld the nut to the fan clutch wrench and viola, you have this:
Insert it into the crank and wedge so it doesn't spin, then insert the 19mm socket into it and remove the crank bolt with your breaker bar or impact.
