93accord h22
ok so the other day i was over at nightwolf house and my girl has in the cb with the cb on with ac on. anyways when i was backing out of his driveway i notice my CEL on than also notice my temp gauge was on hot so i pull up his drive way and my cb started smoking like if i had busted a coolant line so i open my hood and it was the reservoir that got overfill and it was pouring out. i check the CEL and it was code 14 which is IACV which was weird as hell do to the fact that i don't have coolant going to it and it was plug in. so i reset the ecu and i didn't get a code again we filled the radiator with more coolant and car ran fine. nightwolf believe it could be a head gasket (im hoping its not) leaking inside the block but i see not coolant in the oil and the car does not stutters so it cant be leaking into the cylinder/or combustion chamber it been it been like 5 days with out a problem but im noticing that my cooling fans turn on one after the other and not at the same time im also noticing that the upper and lower radiator tubes have no pressure like for ex. i went for a rough ride on the highway to to see if it builds up pressure on the tubes but when i get home there's no pressure and can easily squeeze the tube (yes they are hot ) i can even open the radiator cap with no problem.
i cant seem to figure this out at all car hasnt overheated since that day and havent notice the cb running any different
what could did be
what could did be
