Motor Oil Thread
    Motor Oil Thread
    I figured I would start up a thread dealing with what brands, weights and results people are getting from various different oils under differing circumstances. Thinking about using a format as well (moderators edit as you please) for ease of organization and reading. I may edit the initial post with averaged results if this catches on.
    Format:
    Motor:
    Oil Brand:
    Oil Weight:
    Usage: (Daily driver, occasional track day, full race car, etc.)
    Additive: (Lucas oil stabilizer, Liqui Molly Ceratec, None, etc.)
    Filter:
    Review:
    Guess we will see how this goes.
    Motor: F22A1 built head
    Oil Brand: Castrol GTX
    Oil Weight: 5W-30
    Usage: occasional track day only
    Additive: Used to add Zmax before the trip to the track, but regular oil changes might make this unneccessary
    Review: No complaints whatsoever. This stuff does not leak where synthetics would (and have) in my application.
    I think we should add an Oil Filter category: Wix Permium 51334
    MRT
    14.38 @ 98.66mph
    Current fastest Laguna Seca Lap: 1:52.346
      Motor: '96 Honda F22B2
      Oil Brand: AMSOil Signature Series
      Oil Weight: 5w30 100% Synthetic
      Usage: Daily driver
      Additive: N/A
      Filter: K&N PS-1004
      Review: Love the stuff, a bit on the expensive side but it does stay cleaner than cheap off the shelf stuff. I always did a filter only change @ 3000 miles.
      Motor: '01 Ford Zetec (2.0)
      Oil Brand: /Weight:
      Break in: Castrol SAE 30HD
      Running: AMSOil 5w20 Synth
      Usage: Daily driver, occasional track day/hard driving
      Additive: N/A
      Filter: K&N PS-2009 (Quaker State for brake in)
      Review: Same as with the Accord engine as far as the AMSOil goes. The Castrol was used for break in. Ran if for 500m and did a filter change. Then broke her in good and hard. Tore the engine down after 70k and there was barely a mark on the cam lobes or journals no sludge or varnish buildup inside the block. Love the SAE30HD, just not good for cold weather.
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        Edited to add the filter category.
        Motor: H22A
        Oil Brand: Mobil1 Full Synthetic
        Oil Weight: 5W-30
        Usage: Hard daily driving
        Additive: Lucas full synthetic oil stabilizer
        Filter: Purolator Gold
        Review:
        So far I've been alright with this combination. Usually use 4 quarts oil and one quart additive. I change my oil and filter every 3000 miles but it doesn't come out quite as clean as I would expect. I ran Castrol full synthetic one oil change and it was the only time i had ever had to to off my oil before my change interval so I went back to Mobil1. Thinking about changing to a higher quality oil such as Liqui Moly or AMSOIL and ditching the additive.
          Motor: F22a6
          Oil brand: Royal Purple Synthetic
          Oil weight: 10w40 it was on sale for $1-3 a quart so I got like 20.
          Usage: Daily driven, and sees high revs regularly.
          Additive: None
          Filter: Bosch
          Review: Excellent oil, just expensive if not on sale. I burn less oil, and it idles much better than with the Valvoline Max Life I usually use. Much cleaner as well, I took the valve cover off recently to adjust the valves, and the rocker assembly was silver and clean. I've driven over 4k miles and the oil isn't purple, but gold now. Idk what happened there, I'm guessing it mixed with the oil left over upon the change. I recommend it anybody who can afford the stuff.
            Motor:stock f22a1 turbo
            Oil brand: pensoil
            Oil weight:10w30
            Usage:ummm beat on daily lots of racing......
            Additive:lucas oil stabilizer about 1/4 of qt for winter and 1/2 qt for summer
            Filter:depends I like k&n for performance days but use Bosch for daily driving perposes.
            Review: great oil on its own. For a turbo application it dose not break down as quick and dose not get as hot after hard runs. With the Lucas I noticed it dosent break down between oil changes as fast even with my hard driving daily. I like it.
            my new turbo build
              Engine: F22A1 stock
              Oil Brand: Cheap Mobil conventional
              Oil Weight: 5w30
              Usage: Daily driver. My car burns some oil because the engine was beat to death in its previous life and it probably needs rings.
              Additive: None
              Filter: Subaru OEM H6 filter. Made by Tokyo Roki
              Review: No issues to report, builds oil pressure immediately on cold start w/ the Subaru filter. Subaru filter doesn't leak either. Sometimes have issues with Purolators and Wix leaking
              2002 Subaru Impreza WRX
              Engine: EJ205
              Oil Brand: Shell Rotella T6
              Oil Weight: 5w40 Synthetic
              Usage: Weekend car, sometimes beat on.
              Additive: None
              Filter: Mazda OEM for 2004 RX-8 made by Tokyo Roki
              Review: Excellent oil, nice and full, fairly clean after 3k OCI. I like it because it's diesel oil and is actually designed for high heat turbo applications....
              I would be using T5 10w30 semi synthetic in the CB7 if it didnt burn so much oil
                Originally posted by 4cam4banger View Post
                Engine: F22A1 stock
                Oil Weight: 5w30
                Additive: None
                Engine: EJ205
                Additive: None
                I switched from redline 10w30 to rotella t6 in my 3000gt vr4. couldnt be happier, its a great oil
                  Engine: F22A1 stock
                  Oil Weight: 5w30
                  Additive: None
                  Engine: EJ205
                  Additive: None
                  Out of curiosity, why would you choose to run a filter from another vehicle, from another manufacturer? I've never had leaking issues when using the right filter for the right vehicle. Also, are you watching the oil pressure on a gauge?
                  Oil Brand: Cheap conventional (Quaker/Penz/Castrol, basically whatevers on sale at the time)
                  Oil Weight: 5w30
                  Additive: 1/2 bottle of Lucas Oil Stabalizer
                  Filter: Parts house special
                    Engine: H22A Built head
                    Oil Brand: Royal Purple
                    Oil Weight: 5w30
                    Usage: Seldom driven during summer, stored during winter
                    Additive: None
                    Filter: Mobil 1 S2000 Oil Filter
                    Review: Love the oil, idles a lot better than the Mobil 1 I used to use. I realized that the motor is a lot cleaner also. Took the valve cover off and the valve train is cleaner and even after doing oil changes every 3000 miles or every year since I rarely drive my car I see that the motor isn't extremely dark.
                    1991 Accord Sedan LX: http://www.cb7tuner.com/vbb/showthread.php?t=173444
                    1991 Accord Wagon LX: http://www.cb7tuner.com/vbb/showthread.php?t=209652
                      Motor: 2010 Mazda 3 2.5L
                      Oil Brand: Penzoil Ultra-Platinum full synthetic
                      Oil Weight: 5W-20
                      Usage: Daily Driver
                      Additive: N/A
                      Filter: Puralator PureOne
                      Review: I noticed a bump in gas mileage by about 5%-7% and the oil appears cleaner than before when I used conventional. I personally have not performed an oil analysis, but the results I've seen on this stuff appear very promising. The downside; you can't find this stuff in the stores, so you have to order online.
                        Motor: F22A4
                        Oil Brand: Mobil/Delvac 1300 Super
                        Oil Weight: 15W40
                        Usage: Occasional daily.
                        Additive: None
                        Filter: Bosch
                        Review: Keeps oil consumption down. Seems to stay cleaner longer than other oils I have tried.
                        Cheap, less than $20 a gallon. Not recommended for normal use. Works great for an engine that burns oil excessively.
                          Motor: D16A6/D16Y8
                          Oil Brand: Valvoline Full Synthetic
                          Oil Weight: 5w-20
                          Usage: Everyday, spirited drives
                          Additive: n/a
                          Filter: OEM Honda Filtech filter.
                          Review: Since rebuild has considerably cleaned the inside of the engine.
                          wat?
                            Motor: Mild built h23a1
                            Break in: Non detergant 30 weight
                            Oil Weight: 5W-30
                            Usage: Daily driver, beat on every now and then when im bored driving around. lol
                            Additive: None
                            Filter: Fram Extra Guard
                            Review: No complaints at all does what its suppose to do... lubricates lol.
                            1999 Dodge Ram 1500 4X4
                            Motor: 5.9L V8 Magnum
                            Oil Brand: Castrol High Mileage
                            Oil Weight: 10W-30
                            Usage: Trailer Puller, Off road bashing (occasionally), daily commute (if the cb is down, 15mpg tops sucks)
                            Additive: None
                            Filter: Fram Tough Guard
                            Review: No issues or complaints to be given!
                            If at first you don't suceed, then skydiving is not for you.
                            I try not to down talk anyone, when I read my old questions I realize I was an idiot too.
