Good Evening,
I was putting a new harness in my CB7 today, and addition new power steering hose that goes to the pump from the rack, not sure what it's called. I pulled that pan off that protects where the lines that are for the power steering fluid. In the pan I found 1 of my power steering rack bolts lying there, in the past this had happened as well. I tried once again to tighten the bolt but the threads are stripped in both holes on the sub frame. Has anyone else ran into this issue? I was thinking about using a tap and bigger bolts or should I replace the sub frame?
