So the incessant clicking of the halfshafts became concerning to the wifey, so I got a couple replacements to put in. Having the day off today, my brother and I went out to put them in.
And that's when we discovered that Hercules was the last person to do halfshaft maintenance on this car.
OEM torque specs are 180-184lb./ft. depending on which resource you go by. He broke a breaker handle yesterday trying to loosen the axle nut. And today we had a made in america S&K breaker handle flexed about 5 degrees from straight with a cheater pipe on it and using heat on the axle nut. So it has gotta be in the 300-400lb/ft range on there. I could see how this way overtorqued nut could put undue wear on the wheel bearings.
For CYA purposes, we tried to crack the passenger side axle nut and it's the same situation. It doesn't move at all, with cheater and all.
So I'm gonna take it to work tomorrow and have a buddy use his 1100lb/ft max impact on it. Will report back when progress is made.
Just thought as a PSA it might be worth investigating if others are about to change halfshafts. These mfr's are TIGHT sometimes!
I guess it really comes down to location, I deal with alot of rust from winters, salt and brine. I'm a real stickler on exposed threads-inner to outer tie rod connection, alt + p/s tensioner hardware, auto kickdown cables, throttle cables, castle nuts, radius rod ends etc...all these items and much more get sprayed periodically with fluid film but grease and/ or oil do the trick too. I always enjoy taking my stuff apart again just b/c it always comes apart very predictably w/o any corrosion issues. I even grease the lug studs on the hub and the balljoint tapers as well, been doing this for 10+ years now. I know I am totally against the grain on this issue but I have been disgusted with how many leave things "dry" to seize, rust and corrode. Rear toe adjusters are a perfect example of this, they should've been greased up from the factory as water can penetrate the small openings and follow the bolt. I always stake my axle nuts too and sorry for the
