so, i'm still having this problem. basically, the problem i've described in every other past thread i've posted. no cel is currently coming on. it was code 43. i've already put in a few oxygen sensors.
egr valve was most recent. my friend thought that was the issue. he thinks there's something electrical regarding the egr valve. any ideas? the cel is NOT coming on. i have not cleared the code. the car is still practically stopping dead. almost choking up. does not shut off.
replaced so far:
* egr valve
* spark plug wires
* distributor
* spark plugs
* fuel filter
* fuel pump
the iat sensor is at around 1. normal readings are 1-4.
i've been told the catalytic converter is fine.
i may have tested it wrong, but i tried to test the injector resistor box. see this diagram:
http://s133.photobucket.com/user/Gho...check.gif.html
replaced so far:
* egr valve
* spark plug wires
* distributor
* spark plugs
* fuel filter
* fuel pump
