I am following this tutorial from Honda Tech Site https://honda-tech.com/forums/honda-...-pics-2830570/ (sorry yall didnt have on here). It is for fixing code 1 on abs for pump over run. Am at getting the gold ring off inside of ABS Pump. What is the effn trick? I have tried many different angle picks and most i can't even get under the ring. Anyone did this before and can briefly explain. Thanks.
How to get gold ring out in ABS Pump
There is a thread, but I just fixed the photos.
http://www.cb7tuner.com/vbb/showthread.php?t=203346
I used a pair of right angle screwdrivers to pull the ring out (picture in the thread).90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostThere is a thread, but I just fixed the photos.
Originally posted by zedjr10 View Postcool, that is what i need. Now i have to go get 2 offset screwdrivers. Thanks.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostI used them because I already had them. Put a 90 degree bend in a couple large nails - anything that will allow you to hook a couple of the slots. I just wanted to avoid pulling it with a pair of pliers and damaging it.
That's usin' your noggin! So, you got it out?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostThat's usin' your noggin! So, you got it out?
I have never attempted it. I think most guys at this point just eliminate the system. You might check with your local Honda dealer if they even still have the equipment and request a quote.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostI have never attempted it. I think most guys at this point just eliminate the system. You might check with your local Honda dealer if they even still have the equipment and request a quote.
$95 sounds reasonable.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
