I am about to replace driver side motor mount and tranny mount. I already did the front strut motor mount and will do rear when i take off IM. I ordered some ebay motor mounts a while back and now wondering if i should get some others. What are some good brands as oem is ridiculously high? Also do i need to jack up car when taking out driver side motor mount. Is it as easy as it looks?
Engine Mount Question
It can probably be done without a jack because the forward stud is fairly long. I would still recommend putting a jack (or a stack of wood blocks or something) under the engine to limit how far it drops just to minimize the load on the threads while running the nut and bolt down.Originally posted by zedjr10 View PostCan't find Explicit speed. I think I will go with westar mount for the rear. I don't want any poly. Can the drivers side mount be taken out without putting a jack under engine.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
