Hello everyone,
While I was under the car the other day I noticed my trans was leaking fluid from this spot so I figured a seal or two is bad. However I'm not 100% sure which one(s) it could be, even after looking at the service manual and parts diagrams online.
I was planning on buying these as well as a crank seal if I end up having to separate the trans from the motor to do it. Given where it's leaking I'm pretty sure that's what's going to have to happen. Are the highlighted ones below the only trans seals I'll need?
