I have a 92 EX coupe auto w 103K miles and I bought it with this issue. I have searched and read thru 5 pages so far and haven't found any other threads that match my issue, a couple are similar though.
The transmission will move the car in Rev and D4 thru 1 on the selector. The transmission will NOT shift out of 1st gear in any of the forward gear selections. I have hard accelerated, crept, normal accelerated with a hold at the RPM that is should shift, ran it to redline and bounced it off the governor... nothing would get it to shift out of 1st. Sometimes it will act like the transmission is slipping and barely move forward. Otherwise it acted like it was normal except it wouldn't shift up.
I have cleaned the solenoid's, swapped the TCU for one that I have rebuilt with new resistors and is running my sedan 10th Anniversary CB. The PO said he flushed the transmission using the 3/3 method everyone has suggested to those with shifting issues and the fluid is bright red and full so I believe he was honest.
Is the transmission shot? Is there anything else that I can do to try to get this fixed?
