So im having the common temp gauge issue where it just goes to H. Literally 20 seconds after start it goes up to a little less than midpoint and then poof, all the way up.
I have changed ALL sensors ( especially the small single prong) connector/sensors. actual coolant temp is normal (tested) car drives fine, RPM stable etc.
I have heard about some sort of grounding issue. How can i wire it to a ground ? I have some extra wire laying around that i could possibly use.
Thanks !
Thanks !
