Hello, everyone, been a minute!
The CB7 sat since August, and the winter brought plenty of moisture in my neck of the woods (Redwood forest, parked in dirt), and so the whole car get very damp, including aluminum corrosion and what looks to be a little corrosion on the fuses themselves.
I went to start it the other day, and nothing. The relay clicks, the battery had 12V, fuel pump primes, and the dash lights up. Jumping didn't work, hammer to starter didn't work, and wiring doesn't seem to have any evidence of rats chomping away. I get another starter (Denso) same as last time, switch it out, and boom, starts right up three times. I let it run for an hour or so.
The next day, I go out to start it again, notice I didn't connect the negative cable from the battery like usual, and it is now doing the exact same thing as before the starter swap: relay click, fuel pump primes, dash lights on, nothing to starter, and the battery has 13V to it (Odyssey PC680 BTW).
Any help chasing down this electrical gremlin (most likely) would be much appreciated. Should I pull out the main relay, battery 80A fuse?
