Alright, so the search function on the boards have gone hay wire, so maybe someone knows the answer off by heart.
My project car (see other threads by myself), is almost up and running, but I am having a little bit of an issue.
The turn signals don't work (they dont come on, or flash), but the hazards DO. I have done so far:
Changed Hazard Switches
Changed Relays
Changed Turn Switch
So far, nothing. I tested for Continuity between the hazard switch and the hazard relay (Green Red), and Turn Switch and Haz/Turn Relay (Green Red), and it is there... but there is no power on that line (I don't know if there is suppost to be). I've tried adding the power also, and it clearly works (the switch, and the lights coming on, not flashing).
The Green/Red (Haz-Relay) CLEARLY comes into the switch, and then when you put direction, it completes the circuit, but there is nothing coming IN on Green/Red to connect the circuit WITH... No power, no ground, its only connected to the same wire that the Hazard Switch is on, which is suppost to connect to the relay (which I am assuming it is, since that relay works!).
Thanks,
Kev
Changed Relays
Changed Turn Switch
Thanks,
Kev
