ok guys i had a bad pull to the right from my freaking car being out of align, most didnt even want to drive me car it was so bad but here we go i will post pics later
Tools you will need:
String
Wrench to fit tie rods ( will post size later )
THATS IT!!!
( my car currently has stock height also im on 13 inch rims so i didnt have to take my tire off but if you are lower or on stock rims her are the other tools you will need)
4 way lug nut remover
jack
Step 1: have a friend hold the string while u go around all four tires....
(if you have to jack up your cb and secure it with stands)
(also remove tire)
Step 2: Loosen the adjusting nut on inner tierod.....
Step 3: Make adjustments till all tires have the string touching at the 9 and 3 or the tire, (*as if u were looking at a clock)
Step 4: Tighten the adjusting nuts when best look is achieved, (notice this is front wheel alignment not rear so if the rear doesnt touch see a shop)
Step 5: Go for a test drive, if car pulls to the left, loosen the adjusting nut on the front driver side tire, which basically brings out the back side to make the tire straight, vice versa for if the car pulls left.
So basically if your steering wheel sits to the left when you drive, you need to find which tire isnt straight with the steeriing wheel straight, and adjust the inner tierod![TU](http://www.cb7tuner.com/thumbsup.gif)
Experiment till steering wheel sits just like you want it, took me two times of adjusting, make sure to tighten adjusting nuts on tierods when done,
goodbye paying for front end alignments
String
THATS IT!!!
jack
(also remove tire)
![wave](http://www.cb7tuner.com/wavey.gif)
