its not, i just thought the name was cool
:edit: i also sleep a lot too
steelbluesleepR : 1990 Accord LX
thanks, ill ask for one christmas (no income). i need to get an orbital buffer too, my exterior is looking kinda faded is some spots.
Leave a comment:
i usually use an orbital sander where ever i can. that kind of sander is the easiest way to see if you have sanded away all the pits and uneven surfaces.
i wouldn't go any courser than 320g. then just work your way up from there. later.
Leave a comment:
i know you do, typeG, you inspired the work in my engine bay and i have learned a lot from your DIY's. however, being in college, i dont have any time to polish anything except on breaks, and then i see my girlfriend back home! looks like i have to wait until at least christmas to do anything. when i do, though that valve cover and a few other things will SHINE.
on a related note, how do you sand large surfaces? i have used the dremel sanding method on parts of the valve cover, but that takes forever. right now i am hand sanding everything, and would like some arm stregnth left afterwards.
Leave a comment:
you're going to need more pics of your engine because i like to see polished metal. later.
Leave a comment:
fixing photobucket's fuckup by Jayson Carey, on Flickr
All mods are currently in progress, car has been off the road for 4 years.
Engine
________________
Shaved bay, smoothed firewall
Bisimoto heat barrier intake manifold gasket
h23 intake manifold with butterflies removed
Bisimoto stainless header (soon)
Greddy Evo1 CD5 cat-back exhaust
Custom test-pipe
Deleted cruise control
Deleted power steering
deleted charcoal canister
deleted MAF box
Deleted a/c
Battery relocated to the passenger side of the trunk
Tucked brake lines
Custom engine harness with firewall quick disconnect
Relocated fusebox
Suspension
_______________
KYB GR-2 Struts
Sprint Blue lowering springs (-2.5, -2.5)
Neuspeed Polished front strut bar
5-lug swap, v6 accord front, prelude rear hubs
Megan Racing rear lower control arms
Energy master urethane bushing kit
2nd gen eclipse O-Z wheels, painted white
Exterior
______________
Stock B-49M Laurel Blue Metallic
92-93 sedan trunk conversion
92-93 sedan OEM taillights
DIY 1-piece grill
DIY fiberglass eyelids
Shaved antenna
Shaved rear emblems
Ebay clear corners
Ebay clear bumper indicators
Farenheit xenon cool-blue low and high beam bulbs
30% tint all around
Legend coupe lip
cb7t and club decals
Interior:
_______________
DIY shortshifter (lowered bucket, cut shaft, shortening bracket)
OE black leather door panel conversion
OE black plastics
OE black leather armrest
92/93 SE airbag dash
DIY black ultrasuede pillar-covers and headliner
DIY black/blue ultrasuede shift boot (thanks mom)
DIY volt-guage-pod smoothed into steering column cover
Body-color matched dash trim
Personal boat steering wheel
NRG quick-disconnect
Blue 92 Integra headrests
White integra clock
Pilot shift knob
ICE
________________
JVC CD MP3/WMA head unit
Cerwin Vega HED-1502A components
Kenwood 505w amp
2 JL 12W0's
DIY body-color mirror trim panel tweeter pods
DIY fiberglass-faced sub box and false trunk floor
Dual 6-1/2" rear speakers
In Progress
____________
Full wire tuck
Shaved engine bay
H22 swap
Looped power steering
Deleted vacuum black box
Relocated fuse box
When I first got it in my junior year of high school from an old, awesome woman who was the first owner (this is after a few small mods):
the summer after my senior year of high school, it started burning a LOT of oil, and eventually one of the rods decided it liked it better outside the motor:
dropped in a remanufactured motor, got the windows tinted, then found some altezzas in a junkyard and tinted them red. I really liked this at the time (still kinda do, and they almost look like old audi quattro taillights)
slowly worked more on the motor
lowered it on junkyard-sourced KYB GR-2's and sprint blues, then bought some 10th anniversary accord 6-spokes and hand-polished them
then I added a 5th gen accord lip, made some fiberglass eyelids and a custom grill, and picked up some Motegi MR-8's. this was taken at one of the Show-Me Showdown carshows at the ducks stadium.
And I built a fiberglass-faced sub box for my trunk:
eventually the red tint started to fade and chip away, and my friend wanted the altezzas, so I traded him trunks, upgrading to the 92-93 sedan trunk.
the car was looking great at this point, but ever since that replacement motor, things hadnt been right. i went through two or three cracked intake manifolds, massive overheating, a broken IM stud, etc, so i decided to swap it out and try to find an H22 originally. unfortunately, the H i picked up had a cracked block and a broken connecting rod, so i swapped plans back to the f-series motor. in the process i decided to clean the bay up a little bit. that little bit escalated quite quickly. My goal eventually became to create the cleanest accord bay in the world. It sounds a bit nuts, but even 8 years later, that will still be the case. This is where the progress mostly died. I got another vehicle, went back to college, then eventually started my adult life. For a while, I'd go back home and work on it, eventually getting the bay painted, but then life happened. It's currently sitting in a storage unit near my mom's house, 200 miles from where I currently live.
fixing photobucket's fuckup by Jayson Carey, on FlickrLast edited by steelbluesleepR; 05-05-2018, 03:06 AM.Tags: None
Leave a comment:
