If you want to make power for little money... hit up a junkyard, or www.car-part.com
Look for:
F22A4 header - $15 (90-91 Accord EX)
F22A6 camshaft - $25 (92-93 Accord EX)
F22A6 ECU - $25
H23A1 intake manifold and throttle body (from a Prelude SI, 92-96 I believe) - $45
F22A6 IAB "black box" (to be able to activate the secondary runners, the intake air bypass, in the H23 manifold) - no price listed... probably $10 or so.
The prices are from my local junkyard, which is average for most things.
Your stock F22A1 engine's horsepower rating is at 125. The F22A6 parts alone will bring you to 140. The A4 header should get you to 145 (the ONLY difference between the A1 and A4 is the tubular header on the A4... which is superior to both the A1 and A6, which both have cast manifolds) The H23 intake manifold and plenum should add another 5hp or more... no exact figures are set for that.
If you do the camshaft, which isn't a HUGE part, but it helps, you're going to want to replace all the gaskets and seals you come across... good preventative maintenance anyway! That'll be another few bucks... but not a whole lot.
Get a cheap short ram intake. Have a muffler shop slap a 2.25" system for you.
The stock Honda parts would run about $120. A cheap short ram can be had for $50 or less. Exhaust... depends where you go. I paid $450 for new piping, cat, and muffler. You can probably get away with keeping your stock cat. Find a cheapie muffler on ebay, maybe a used one. Pay for piping and labor only. $200 at most for everything, I'd say.
So... that's under $400, and you can gain a minimum of 30hp... that doesn't include the intake and exhaust gains.
These things have been said over and over again... but I figured I'd make a post stressing just how simple things were!
Look for:
F22A6 ECU - $25
