Well, I couldn’t find the old numbers so I re-weighed everything. Here is the list
Hatch carpet: 3.2 lbs
Side Floor Box lids: 2lbs (1 lb each)
Right Side Floor Box: 6.6 lbs
Left Side Floor Box: 3.4 lbs
False Floor attachment piece: 5.4 lbs
False Floor 13 lbs
Side Storage Box Back: 2 lbs
Total: 35.6 lbs
So if you were to remove everything I have removed as well as the cover, spare, tools, and jack then the grand total removable from the back is 108.8 lbs. This doesn't include the two side pieces that go all the way up where the back of the seats lock in place. These pieces can be seen on the sides (the carpeted stuff) in the picture in my last post. They are pretty big and probably weigh somewhere between 5-10 lbs total. So if you remove those you could be looking at a possible savings of 120 lbs just from the hatch area. If you go the next step and start pulling out all of the tar that is down there you could possibly get rid of another ~5 lbs. Pretty substantial losses for simple dead weight that you nor anyone else would see on a normal basis.
False Floor 13 lbs
Total: 35.6 lbs
