Old 07-15-2009, 07:33 AM   #1
Raf99
Raf99 : 1993 Accord EX
Big thanks to...
DarkCloud, TypeG, rocketman_471, cb7rush, Theos92VR4(x2), almostJDM, , NightmareCB7, xkjnboix, almostJDM, H23CB7, tommi, 1990[H]accordex, treyd82, dannyd, bmxicansd, STREET-SPEC, 93a-lude, lindiz, DanCan, fleetw00d, Excalibur, Losiracer2 and many others for the help
**Special HUGE thanks to James at Raven Auto Sports in Halifax, NS for helping build, tune, and bring this monster to life!! Without him this car would not be where it is now!!**
410WHP/296TQ @ 17PSI
Engine
JDM H22A engine
Skunk2 intake manifold
Manual tensioner
Darton sleeves
Eagle H rods
Arias forged pistons (8:5:1)
Cometic head gasket
ARP main studs
Cometic lower engine gasket kit
Endyne oil pump
Greddy timing belt
Greddy balancer belt
Mishimoto half radiator
Mishimoto slim radiator fan
Mishmoto power steering reservoir relocation
H22A 68mm throttle body
MSD Ignition system
Walbro 450lph fuel pump
Internal distributor coil mod.
Battery relocation to trunk
Fuse Box relocation
Full Wire tuck
Full A/C delete
EGR/Canister full removal
3" Full exhaust + 18" Resonator + Flowmaster muffler (no cat)
ESP engine mounts
ESP front lower traction bar
ESP 3 point upper strut bar
ESP alternator relocation bracket
Transmission
T2T4 LSD Transmission 5-speed transmission
- Synchrotech bearing set
- Synchrotech carbon fiber sychro set
- Synchrotech F23 shaved 5th gear
- Assco 12lbs flywheel with ARP bolts
- Tilton twin disc racing clutch & pressure plate
- MTEC shifter spring kit
Go Gear
GT35R Turbo (.70 compressor, 56trim) w/ oil and coolant lines
Mishimoto Intercooler
Tial 50mm BOV
Tial 44mm WG
Top Mount 44mm Turbo manifold
RC 1000 High Impedance injectors
GM 3bar map sensor
S300 V2 ECU with boost control
AEM fuel rail
AEM FPR
AEM A/F ratio gauge
AEM boost controller
AEM boost gauge
Oil pressure gauge
Oil catch / valve cover 2x10an fittings setup
Fast Turbo feed and outlet turbo lines
Exterior
Tein Super Streets
Braided steel brake lines
Rear disc swap
17" DAI Mirage rims w/215/40/17 +38
EBC Front drilled and slotted rotors and pads
EBC Rear drilled and slotted rotors and pads
Front SPC front camber kit
Rear Ingals angle camber kit
Fat Four Customs rear LCAs
Fat Four Customs rear toe arms
Ractive rear upper strut bar
Ractive rear lower tie bar
Clear bumper signal lights
JDM power folding mirrors DIY (in USDM housings)
JDM side marker lights
JDM intersection lights, relays and harness
JDM yellow fog light bulbs
Red/Clear Sedan tail lights
EDM rear fog light
80% tint on rear windows and back window
OEM Window visors
Shaved antenna
Shaved logos
91 DIY front grill
Rear camera DIY into trunk key hole
95 JDM Honda Accord front lip‏
95 Accord EXR rear lip
95 Accord side skirts
CB7 JDM one piece black housed headlights /w
- Yellow high beam shroud
- JDM yellow high beam bulb
- DS2 Mini projectors w/ electronic cut-off shield (theretrofitsource.com)
- Gatling Gun mini shrouds (theretrofitsource.com)
- Phillips 85122 bulbs (theretrofitsource.com)
- 100mm halo rings high beams (theretrofitsource.com)
- 90mm halo rings low beam (theretrofitsource.com)
- Wiring splitters (theretrofitsource.com)
- HID ballast (theretrofitsource.com)
- Headlights shields
Interior
97 Prelude front seats
Black dash swap
Dyed black floor mats
Dyed black rear seat
DIY black interior pieces
Black carpet swap (stockinteriors.com)
Complete DIY trunk redo with black fabric
Silver speedo/RPM/cluster rings with color matched cluster background
Momo steering wheel
Full blue LED gauge/dash conversion
ICE
Alpine IVA-D310 In-dash 7" DVD screen
Alpine IVA-D310 brain unit
Alpine I-Pod interface adapter
Alpine MRV-1507 class D 900W OMS
2 x 400W Clarion 10" subs
Alpine Flex5 MRP-F365 amp
Qlogic corner enclosures w/
-Alpine crossovers
-Alpine 300W 6-1/2" 2-Way component speakers & tweeters
Pioneer 180W 6 1/2" rear speakers
Pioneer 140W 5 1/4" front speakers
If you read this far congrats! This list is getting way too long
Future Plans
Carbon fiber hood (do not have..)
Carbon fiber trunk (do not have..)
Big Brake upgrade
************************From this point below are pics when I started my MRT. As the pages go on, so do the updates and pics
Old 07-15-2009, 01:18 PM   #2
PointBlank
PointBlank is cool... so far.
Love the rims and swap, not feeling the lights all around.
Was that first one an old pic and your back to stock, or are the other ones older pics?
Originally Posted by chessboxer View Post
We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
PointBlank is offline   Reply With Quote
Old 07-15-2009, 01:25 PM   #3
Clean_4th gen
Clean_4th gen is cool... so far.
Clean! What size are those wheels?
1990 Accord EX
Clean_4th gen is offline   Reply With Quote
Old 07-15-2009, 09:38 PM   #4
19TcappaLX
19TcappaLX is cool... so far.
WOW!! bro your cb is nice,love that color.those rims are nice also.got some interior pics.
19TcappaLX is offline   Reply With Quote
Old 07-15-2009, 10:03 PM   #5
91f22jon
91f22jon is cool... so far.
Clean ass motor looks good
91f22jon is offline   Reply With Quote
Old 07-19-2009, 12:26 PM   #6
Raf99
They are 17".
Old 07-19-2009, 09:09 PM   #7
kouzie
kouzie is cool... so far.
that is one clean mofo......
kouzie is offline   Reply With Quote
Old 07-19-2009, 11:33 PM   #8
vietkid_2006
vietkid_2006 is cool... so far.
Send a message via AIM to vietkid_2006 Send a message via MSN to vietkid_2006 Send a message via Yahoo to vietkid_2006
pretty agressive. but clean! Cb
vietkid_2006 is offline   Reply With Quote
Old 07-20-2009, 02:54 AM   #9
trubluryder
trubluryder is cool... so far.
Damn, that is one clean ass paint. Did you get it resprayed? If not, you took damn good care of it . Btw Most peeps on here may not like your wheels and or the projectors, but I think they suite your car well. Keep it different yet clean
Ps. If you want your projectors to put out better output, throw some HID'S in and aim them right. Now if you want even better output, throw some HID's into the fogs also
"PREPARE for the WORSE, Hope for the BEST" B.T.N.H.
trubluryder is offline   Reply With Quote
Old 07-20-2009, 09:02 AM   #10
F20A CB7
Clean.
Old 07-20-2009, 04:55 PM   #11
jimmybean21
jimmybean21 may have said something they shouldn't have...
clean cb not really feeling the tail lights, but overall it looks good. is your motor stock or have you done some work to it?
jimmybean21 is offline   Reply With Quote
Old 07-21-2009, 08:03 AM   #12
Raf99
Motor is a h22a swap. (see above pic)
Old 07-21-2009, 08:54 AM   #13
F20A CB7
http://www.cb7tuner.com/vbb/showpost...3&postcount=33
A cool diy for 1 piece ebay lights.
Old 07-22-2009, 11:51 AM   #14
Raf99
Thanks, but my headlights are already blacked out. ( can't wait to do the tail-lights though )
Old 07-31-2009, 11:15 PM   #15
Raf99
Old 07-31-2009, 11:32 PM   #16
19TcappaLX
man your grill is HOT,i want to do my grill like that when i get her painted.
Old 08-01-2009, 07:10 AM   #17
91ExSedan
91ExSedan is cool... so far.
Send a message via AIM to 91ExSedan
Swweeeet grill.
http://www.cb7tuner.com/vbb/showthread.php?t=188155
Bought from: ChampCoupe
Sold to:Losiracer2
91ExSedan is offline   Reply With Quote
Old 08-01-2009, 12:25 PM   #18
Clean_4th gen
Originally Posted by Raf99 View Post
They are 17".
Nice, were they hard to find?
I like your front end! Do I spy a 90-91 grille on there?
1990 Accord EX
Old 08-10-2009, 08:58 AM   #19
Raf99
thanks You are correct ( I gotta adjust that one headlight though, it looks a tiny bit off )
Old 08-10-2009, 09:01 AM   #20
Raf99
Thanks! Here's the DIY I did for it, enjoy
http://www.cb7tuner.com/vbb/showthread.php?t=139188
