Enjoy
ENG: Seafoaming an engine through the intake
Enjoy
MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfuckerTags: None
Nope. I've done this one before and had no issues.Originally posted by wherm View Postinteresting. I thought the motor was gonna go boom!
Always happy to helpOriginally posted by dhill_cb7 View PostThanks for the video, something to try in the near future
Never seafoamed a car before...
Not at all. I did it exactly how I was supposed to. And that was a vacuum line.Originally posted by KpoweredCB7 View PostThat's a good way to hydrolock your engine!
I believe it even says on the bottle to pour it through a vacuum hose.
Not that I know of. It was just easier to reach.Originally posted by Junior Smurff View PostIs their any advantage to seafoaming through there vs Brake booster Vacuum line??
For those in doubt, seafoam does actually help.
The more smoke you have, the more carbon you're burning off.
The first time I did this a year ago, I had obscene amounts of smoke.
This time, I had much less smoke. I've also been using fuel injector cleaner fairly regularly.MRT
I would go through the brake boost vacuum myself to avoid hydrolock. Not just dump it into the intake.
The EGR line he used in the video should be fine too though.Last edited by wildBill83; 10-30-2012, 02:06 PM.1993 SE Coupe MRT - 1992 LX Sedan MRT
If you seafoam the brake booster your EGR will possibly get a clean as the gas recirculates.1993 SE Coupe MRT - 1992 LX Sedan MRT
If everything is combusted in the chamber then why do our engines need an EGR? In a perfect world, everything going in would combust.Originally posted by Tippey764 View PostNo because the seafoam has been combusted by the time it reaches the EGR.
Tippey, I know you know that EGR stands for Exhaust Gas Recirculation and is meant to recirulate unburnt fuel from incomplete combustion or rich situations. Seafoam will cause a rich combustion so some of it will go through the EGR.
Also if your motor is at idle and parked the brake booster is doing nothing, the EGR is still working, might as well let it do it's thing.
I was mainly talking about NOT dumping seafoam into the intake manifold without using the vacuum line method. This can cause hydrolock.1993 SE Coupe MRT - 1992 LX Sedan MRT
I really dont see how its any different. Its literally going to the EXACT same place.Originally posted by wildBill83 View PostI was mainly talking about NOT dumping seafoam into the intake manifold without using the vacuum line method. This can cause hydrolock.
Plus it looked like he dumped it into the PCV valve hose. Once again, same ending location as the brake booster hoseLast edited by 93accordexcoupe; 10-30-2012, 06:15 PM.
How much Seafoam can pass through a 60mm opening vs a 5mm opening?Originally posted by 93accordexcoupe View PostI really dont see how its any different. Besides the sea foam passing through the throttle body, its literally going to the EXACT same place.
The difference is the amount of liquid that makes it to the combustion chamber. Liquids don't combust, gasses do.
honestly i just watched the video. I thought u guys were talking about dumping it in the intake, not the intake manifold. 2 different thingsOriginally posted by wildBill83 View PostHow much Seafoam can pass through a 60mm opening vs a 5mm opening?
