MRT
Is their any advantage to seafoaming through there vs Brake booster Vacuum line??
Not that I know of. It was just easier to reach.
For those in doubt, seafoam does actually help.
The more smoke you have, the more carbon you're burning off.
The first time I did this a year ago, I had obscene amounts of smoke.
This time, I had much less smoke. I've also been using fuel injector cleaner fairly regularly.
MRT
No because the seafoam has been combusted by the time it reaches the EGR.
If everything is combusted in the chamber then why do our engines need an EGR? In a perfect world, everything going in would combust.
Tippey, I know you know that EGR stands for Exhaust Gas Recirculation and is meant to recirulate unburnt fuel from incomplete combustion or rich situations. Seafoam will cause a rich combustion so some of it will go through the EGR.
Also if your motor is at idle and parked the brake booster is doing nothing, the EGR is still working, might as well let it do it's thing.
I was mainly talking about NOT dumping seafoam into the intake manifold without using the vacuum line method. This can cause hydrolock.
