I was driving down the highway and my 91 cb7 Se started accelerating by it self went up to 90mph until i put it in neutral, step on the brakes and and got of the highway, but the car was still accelerating until it shut off by it self.
Self Acceleration
Do you have cruise control on your model ?Originally posted by aleks1215 View PostI was driving down the highway and my 91 cb7 Se started accelerating by it self went up to 90mph until i put it in neutral, step on the brakes and and got of the highway, but the car was still accelerating until it shut off by it self.Jesus drove a Honda, he just didnt talk about it like us. Proof - John 12:49 "For i did not speak of my own accord."
Originally posted by deevergoteden das al u ned u no dat u get wurs gas milge tho rite?Originally posted by deevergoteThese cars will never be the best at anything, but they're pretty damn good at everything.
This sounds similar to a problem I had in the past.
For me, my throttle cable was too tight. It should have 10 mm of play.
Check and make sure your's is within spec.
Then, check for any vacuum leaks.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
aleks1215, please give us a little more information on the problem.
Was it a slow acceleration, or a 6k run-till-she-blows type thing?
My wife's LX would cruise by its self around 30-35. It turned out to be a vacuum line coupled with dirty IACV that was making it idle at 2000.
How is your idle? Any previous problems/ known existing problems?'91 EX 280,000 || '90 LX 330,000
_____(me)__________(wife)___
Originally posted by aleks1215 View PostIt went up to 90mph until i put it in neutralHe said UNTIL he put it in neutralOriginally posted by Ghetto_CB7 View PostThe car should not accelerate when in neutral. If it did you have transmission issues.
The engine can rev higher, but you should not accelerate in neutral.
OP - Does it idle normally when you start the car, Or are the revs excessively high?
My 5.7 LS1 Holden Ute
I just had install an alarm system with the auto starter.
I was at the highway, and i was going to pass an old lady and i accelerate all the way, but the car didnt stop when i stop accelerating, when i put it in neutral the idle when all the way to seven or eight. I was trying to stop the car with both breaks, i couldnt turn it off right away because i had started it with self started so the key wasnt working so once i got it to stop i couldnt turn it off. I thought the car was going to blow up since i just put it in parking but the idle was on seven or eight, but the car shut off automatictly.
Did the throttle stay down?Originally posted by aleks1215 View PostI just had install an alarm system with the auto starter.
I was at the highway, and i was going to pass an old lady and i accelerate all the way, but the car didnt stop when i stop accelerating, when i put it in neutral the idle when all the way to seven or eight. I was trying to stop the car with both breaks, i couldnt turn it off right away because i had started it with self started so the key wasnt working so once i got it to stop i couldnt turn it off. I thought the car was going to blow up since i just put it in parking but the idle was on seven or eight, but the car shut off automatictly.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Dont these plates get held open by built up gunk in the throttle body?Originally posted by cloudasc View PostCheck your throttle cable, maybe even pop off the intake pipe and look at the metal plate inside the throttle body. It should stay closed via a spring mechanism until opened by the throttle cable.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
It is possible, thats why I suggested he remove the intake pipe and look at the throttle-body plate, its also possible the spring loading mechanism to keep it shut failed too. If in fact his throttlebody has failed, I would suggest if he already hasn't to do an h22/h23 plenum & tb swap, provided the engine underneath the hood is the one that came with it from the factory. (91 SE should be an a6)Originally posted by Accord problems View PostDont these plates get held open by built up gunk in the throttle body?
