pnp means to "port and polish"
f22a1 build up
Originally posted by jas_r34would you have to reprogram the ecu if you uprgrade your IM to F22A6 or H23 or do you just slap it in n drive?
That is, of course, unless you've hooked the runners up to open via vacuum.
grr, i keep hitting 'next thread' thinking it'll go to page 2... nope, so i replied to this on someone elses' thread... oops
anyway
god damn this is confusing.
h22 runners <--- wtf is that?
So, bottom line here, Will an h22 IM and TB directly bolt up to a f22a1 engine?
Can I use it effectively with the ECU from an LX? Should I get a new ECU? if so, what one from what accord/engine?
This sounds more and more like a can of worms >:C.
If i get the H22 TB, would cruise control still work? i read somewhere that the skunk2TB dosent support cruise control.
sorry if i seem thick headed, this is all pretty confusing and i want to get my ducks in a row before i do something.
Thanks
godfuckingdamn. do some researching.
runners are the bottom part of an intake manifold. The top part is the plenum, which the tb is attatched to.
the h22 runners will not bolt on to the f22a head.
you can use your stock ecu, but it won't run to its full potential. if you want to get the right ecu, it will be a chipped ecu, tuned.
now fuckin search.
My red Accord project link in my signature goes along the same concept you're trying to achieve. I did all the performance modifications you can do without touching the block (keeping the stock 8.8 CR) and using 87 octane gas. It is a reliable and peppy daily driver. I netted 155 whp/127 wtq on a Mustang roller dyno, which supposedly is known for lower values than a Dynojet.
HondaFan knows what he's talking about.
ok. ill put it this way.
h22 IM= will NOT bolt on an f22a motor
BUT you can use the plenum tho. that plenum is the part were the TB hooks up to. if you take the bolts off the top of the IM then youll get that top part. its the plenum
BUT the h22 AND h23 PLENUMS WILL bolt onto the f22a6 runners(the runners is the part thats left over when you take the plenum off.)
make sence?
yeah that makes way more sence. I just looked at the diagram. I thought the plenum and runners were all one unit. Once i saw that i knew what you were talking about.
But, ... maybe i should do some other research >:C
the h22 plenum will directly bolt onto the f22a6 runners. But would they directly bolt onto the f22a1 runners?
