So I've been board and decided to do some quick polishing on my valve cover and the plenum, iacv, Fitv, and air boost valve.
J/K, but a P13 is fairly cheap and you only need to run 1 wire for the IABs. If you ever go that route I would like to eat off your polished motor.
I would. But how would I be using the p13 to run my f22? I thought the p13 was for an h22
I thought thats what you meant. The only thing is the p12 is from a prelude and adds roughly 10hp so I don't know which would give more of a benefit the prelude ecu or or the plenum/runners with the pt6..
