running 93 octane
    running 93 octane
    Would I need to run 93 octane and higher if I were to N/A my F22A1 with higher compression pistons, rings, injectors, or could I use regular 87 octane with F22A6/H23A1 Honda Motor Co. parts and ECU? This is a issue with me because I want to modify, but since 93 octane is up to $3.50 and up, I'd rather add rims and a bumpin' stereo and leave the engine modifications alone. What do you guys think? Have you had issues with 93 octane with modified F22 engines or is this more of an issue with H22's?
    ~DirtySouthHonda
    stick with the rims.
    14 Ford Focus ST - stock(ish) - E30 Tune + Green Filter =
      lol
      Originally posted by Makaveli2k
      Just goes to show, leave the JDM poses to the Nimble, sleek, asians. =)
        Ok..... Anybody else?
          Run small amounts of 87, 89, 91, and 93 octane. If you hear it ping on any of those fuels, move up to the next octane until it stops pinging.
            Ok...... Anybody with a F22A1 w/ mods, comment on this octane issue please.
            ~DirtySouthHonda
              What CR are we talking about here? Which H23 parts will you be using b/c H23 pistons won't work in a stock F22 block and it wouldn't be safe anyways. Ignition timing plays a role in this too. What mods do you have planned?
                Plans for now:
                Exhaust w/ Stock (F22A1) Exhaust Manifold (can't afford headers now)
                Plans for later:
                H23A1 Intake Manifold
                F22A6 Camshaft & Gear
                PT6 Electronic Control Unit
                  Haven't you been here 4 years?
                    Yeah, at least 4 1/2 years, but there are some issues with my car that I haven't dealt with yet. That's one of the reasons why I joined in the first place. And to meet some extrordinary people and their CB7s since I've owned 2 of them.
                    ~DirtySouthHonda
                      Depends on what your compression will be, yes you will need a higher octane.
                      My swap thread
                      Main relay proplems?--DIY
                        if u are just running those mods u would be fine with 87 you are basicly making ur a1 into a a6 the f22 is ok on 87 thats what it was meant for thats why the cr is so low so u wouldnt have to run high octane remember our cars were originally intended for ECONOMY...now if u start put higher comp pistons in then u will have to start running higher octane depending how high you go and how good u tune it
                        member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
                          You and Granite CB7 gave me the best answers I was looking for. Thanks.
                          ~DirtySouthHonda
                            ~DirtySouthHonda
                            I have a f22a1 with just header, CAI and cat-back but i used to run 93 in it all the time but since gas went up i run 87 and it runs like shit now, so im gunna go back to runnin 93
                            My cb7
                            h22a
                            5-spd lsd
                            Lord, grant me the serenity
                            to accept the things I cannot change,
                            the courage to change the things I can,
                            and the wisdom to hide the bodies
                            of those people I had to kill because they pissed me off.
                              As long as you do not mess with compression 87 is fine.
                              Gary A.K.A. Carter
                              [sig killed by photobucket]
