Project Acclipse underway!!
    sweet so the firts chip works nicely. No TCU codes and I can feel the car pulls much harder now from a stop meaning that its starting in the right gear. I still havent figured out the speedo thing yet... maby I bumped a relay under the hood or somthing. who knows about wiring??? lol
    MRX: that map for the t25 is actually very close to stock when not under boost! im impressed, with the exception of the odd backfire or hesitation it feels pretty good.
      hows it feel? way better than the stock auto? hehe...
      good about the codes...but, whats ur problem with the speedo ringmaster?
      Formerly 91AccordExR33
      11.68 @ 127mph
      417whp/375wtq
      Sold: 8/2016
        Wow, I hope the ecu that Eric send me is good to go.........
        We'll know in 2 months lol
        ringmaster- did u check to belts?, or any of the wires going from the ecu??
        maybe put in ur stock ecu to test if the speedo thing is cause by chipped ones or not.......
        good luck!!!!
        -Henry
        Great achievements result from great effort
          Henry: what belts are you refering to? all my drive belts for the ac and such are nice n tight. and ya 91accordexr33 im not too sure what would cause that problem... im thinking a faulty relay cause when I turn the headlights on I hear the "click" as always from that relay then a second quieter one just as the speedo dies.
            hey did you check the headlight wires around the charge pipes. you may have chaffed the wires. just ah thought......tends to be the little things you dont think of.
              also.. make sure ur feed line isnt hitting any wires.. lol.. R33 had this problem.. apparently for some reason his feed line was causing the distributor to ground out causing his car not to turn on.. so yeah.. just look over everything.. not having the speedo work is minimal.. and can even be a coincidence unless u put the stock ecu back and it goes away.. if it doesnt.. u fucked something up during install.. lol..
              so now.. MRX.. which version is chip 1?? 1.66 or 1.7?
              Praise The Lowered...
                Did you check to see if the ECU is setup for an auto or manual tranny? I do believe there is a jumper on the ECU board that determines what it will be used for.
                  as far as i know its just a few resistors on the auto that makes it for an auto... it has like 2 in one spot as opposed to 1 in another for a 5spd. I know the one i have is for an auto.
                    did you check your negative battery cable... my speedo went all crazy when i would turn on the blinker or lights or radio and it turned out to be a lose neg. battery cable...
                      Yo ringmaster the ecu is shipped should be there tomorrow
                        hmmn I know for a fact that my neg. cable wasnt on properly cause i just jammed it on there for a test run, i didnt tighten it but ill try that next time.
                        Henry and I are doing some experimenting with our ECUs, he is sending me his Auto p06 that has already been chipped and were going to see if it makes a difference on my car with any of the problems. It is an auto right??
                          wait, so do you have a 5speed ecu right now?
                            I think its an auto, accord r33 would know better......I don't know if he still remenbers
                              and I have an auto
                                We'll see what happens....good luck!!
