Top 20 most powerful turbo setups on the board
    i think i should be moved into top ten easily
    i made 300hp and 315ft piunds on 16 psi. Now going for even bigeger numbers in about a month
    GOT BOOST???
    massive part out on accord almost everything is going
    http://www.cb7tuner.com/vbb/showthread.php?t=125294
      ur car's gotta be running, not blown up
      instagram @mikeymeyagi
        can i get some info: which motor and turbo size plz
        Formerly 91AccordExR33
        11.68 @ 127mph
        417whp/375wtq
        Sold: 8/2016
          f22a1 with h23 head t3/t4 hybrid .50 compressor .63 turbine 57 trim
          GOT BOOST???
            Dammit guys. Now I want to turbo a Honda.
              i can push it haha
              GOT BOOST???
                i can push it haha
                LOL ive been in ur shoes many times now....but ya just gotta build it bigger and better
                  i bet you have and you also have more expeirience but dont tell none i just want to be on the to lol
                  GOT BOOST???
                    i put down 174whp/ 194 torque pretty shitty actually owell... put me on the list.
                      16 psi? was this also on pump gas? i am litterally a week from boosting 14psi, i am not sure if the block will hold or if the internals will melt. any info is much appreciated!
                        Yeah, I was running 16psi and I had a fully built motor with wiseco pistons and pauter rods but stock sleeves, yes it was on pump gas and with 14psi and the same sized turbo you should be able to get around 300hp on a good tune if you noticed my tune wasnt that great. this was only a baseline run.
                        GOT BOOST???
                          yea, 300hp shouldnt be a problem with these motors. i just wasnt sure about the exhuast gas temp on the these stock internals...i have a really good tuner, but 1bar of boost just seems like a lot for a stock engine....oh well, got to live a little to learn right? i will be back in a week to post my numbers on the top ten most powerful turbo setups.....
                            yeha it is very obtainable and not a good idea to do with stock internals but if you didnt notice i had a fully built motor just not sleeved it was bored out balanced and all that good shit. but just watch out who tunes it and be there when it happens because taht is the do or die time its all left in their hands after that.
                            GOT BOOST???
                              by the way: what type of upgraded map sensor did you use?
                                can i get on this list:
                                JDM F22B SOHC VTEC
                                stock top and bottom end
                                t3/t4OB turbo
                                10psi
                                230 whp 245 tq
