Hey guys just thought I would make these available if any one was interested. I have seen a number of posts about staking AIBs to get a little more out of our cars. As you guys know you got to find an AIB plat take all the valves out fill all the holes and hope there are no vacuum leaks. Well I have the solution I am making CNC plats to custom fit your car. I will also be making TB spacers to. If any one is interested in these parts PM me. Here is a picture of an AIB spacer for the h22.
Custom plenum spacers available
Originally posted by drummersteve7 View Postinteresting. same theory as jb weld but looks a hell of a lot nicer.
do you have any interest in cnc'ing some that remove all 8 ports?
making it one large port.
I would be very interested in those!!!
and when do you intend to make these?
for info: h22/h23/f22 spacers are all the same.
IT IS WHAT IT IS
I think that making them with one large hole (as a perimeter spacer) wouldn't be as beneficial to torque as keeping them as seperate runners. It's my understanding that the benefit from the additional low end would outweigh anything one big hole would do. I also think that it would create more turbulence in the transition to the runners, since you'd have one large column of air trying to sort itself out and flow through the runners as opposed to the eight smaller smoother flowing columns that existed once the air passed the plenum's bottom plate, especially if you're using this as an additional spacer with the working IAB plate and butterflies.
vh22 - Are you going to make spacers for both the f and the h TB?
spacers are identical between F and H man.
edit: <- for spacers not TB!
as far as losing low end, haha I was thinking with MY mindstate!
BOOOOOOST!Last edited by drummersteve7; 01-12-2010, 10:35 AM.
Originally posted by drummersteve7 View Postspacers are identical between F and H man.
BOOOOOOST!
lol, I always think about the low end.
Originally posted by Carroll Shelby FTWHorsepower sells cars, but torque wins races!
Originally posted by visualpoet View PostI think that making them with one large hole (as a perimeter spacer) wouldn't be as beneficial to torque as keeping them as seperate runners. It's my understanding that the benefit from the additional low end would outweigh anything one big hole would do. I also think that it would create more turbulence in the transition to the runners, since you'd have one large column of air trying to sort itself out and flow through the runners as opposed to the eight smaller smoother flowing columns that existed once the air passed the plenum's bottom plate, especially if you're using this as an additional spacer with the working IAB plate and butterflies.
IT IS WHAT IT IS
I'm stupid and have a low post count, so gotta ask.... What's this for again?Last edited by Raf99; 01-12-2010, 02:16 PM.
Wanted to give you a friendly warning. Blacktrax sells their spacer, both with 8 ports and modified to one huge port, for $75. The blacktrax spacer has the benefit of isolating heat from the plenum. You'll want to take this into consideration before setting a price for your spacer!My Member's Ride Thread
