Originally posted by 98vtec
View Post
325whp 227wtq H22
90 LX (R.I.P.) http://www.cb7tuner.com/vbb/showthread.php?t=137301
91 EX (DD) http://www.cb7tuner.com/vbb/showthread.php?t=142483
Originally posted by frohawker View PostI figured that much. but I wanna know the rod length needed to not smash valves.
for instance, i am using a 95mm stroke, with h22 AL rods (slightly shorter than an actual h22 rod due to the nature of aluminum) and custom pistons along with PRO3 camshafts. A huge part of them not smacking is the use of cam degree fixtures and clay puddy on the pistons.
Originally posted by 98vtec View Postdepends on the height of the pistons, pin height, deck height, and how much the head has been surfaced among other things.
What block and head are you using? Isn't a stock h22 stroke 95mm? IIRC it is and the f22 is 98mm. I understand the use of puddy and hand turning the motor to make sure there's no piston/valve contact before you fire it up.90 LX (R.I.P.) http://www.cb7tuner.com/vbb/showthread.php?t=137301
Originally posted by frohawker View PostThat's all the stuff I was wondering about on his build. I mean, i doubt he wants to openly share all his build specs because it's his business and means of income.
h22 stroke is 90.x
