Strut Bars
A strut bar is designed to reduce this strut tower flex by tying two parallel strut towers together. This transmits the load of each strut towers during cornering via tension and compression of the strut bar which shares the load between both towers and reducing chassis flex.
What ones should I get?
Installing strut bars
Front
The Front strut bar comes in a few different flavors, but they all connect to the shock tower area and top shock bolts to tie the driver and passenger side suspension together.
What brands are out there, how much do they cost, and what do people think about them?
Generic Bar (Ebay, Megan.. etc) click for pic- Starting at $10+, they are definately worth the money.
Neuspeed click for pic- More expensive, but added bracing gives you more rigidity.
*If you have a swap(DOHC, other than h22) you will have to notch the valve cover for it to fit. The bar will NOT work with h22's
Notching Valve cover
Neuspeed 1
Cusco click for pic - Rarest bar, Designed like a generic brand, so no problems with DOHC. Cannot order these anymore since nobody has them.
Cusco 1
Custom- Fabricated by our own member Wallace
Front Firewall/Strut Brace
Rear
The rear bar connects like the front, but all of the ones on the market only connect to the shock mounting bolts, so the only real difference is the color and brand, and no real difference in performance.
Generic style - Can be had for cheap. May help stiffen a slight bit. If anything, it makes for a good fasten down point for your sub box.
Custom- Wallace - The best option out there for our cars, brace everything!
Custom Rear Brace
