torque is the measure of rotational force (basically) and it is what moves the car.
horsepower is NOT a measure of force, it is a measure of rate of application of force.
the lowest end f22 engine has more torque than the highest end stock B series. this is for a reason....it is needed to move the heavier chassis.
putting a B series in that produces 110-130 lb/ft of torque is going to cost a fair amount of money. It will cost enough to install a B series with all parts and labor that you could rebuild your f22 with turbo rady parts, boost it AND make over 300 hp.
The only peope that will be impressed by a B series in an accord are the ones that are clueless.
